How Do I Seal The Seam In Rubber Flex Piece? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2008, 02:30 PM   #1
How do I seal the seam in rubber flex piece?
Hello all,
I am in the middle of installing a somewhat complicated A/C ductwork system in my NY house.
I have installed anti viberation pieces in both the cold air return and the supply trunks on either side of the plenum.
I do not know if I am discribing it correctly, but I am talking about a black, rubber-like collar that goes into the ductwork to stop any viberation from the air handler. You install it with s- cleat, but you have a seam where the piece of rubber meets.
How do you seal that flex seam? Do you use some type of adhesive or caulk?
Thank you in advance for any help.
Frank D.
faithfulfrank is offline   Reply With Quote
Old 06-26-2008, 06:07 PM   #2
HvacWiz's Avatar
Rewards Points: 252
they do make duct sealer
HvacWiz is offline   Reply With Quote
Old 06-26-2008, 08:19 PM   #3
thank you. I know they make duct sealer......the stuff I'm thinking of as duct sealer comes in a pail and you brush it on. It is an off white color.
I've used it on the A/C unit at my Florida house.
I'm sure that stuff I'm familiar with would not work in this case. Here, I am sealing the seam on a black rubber-like flexible area about 4-5 inches long.
Frank D.
Old 06-26-2008, 11:13 PM   #4
hmm...
hmmm..
I have a roof pack system and the installer did not use any vibration collars in or out. The metal duct work goes right into roof pack. Is this an indication/validation of a cheap install?
Also, he used standard metal tape to seal around the duct work, is there a better product?
Thanks!
bginvestor is offline   Reply With Quote
Rubber roof prices tgf40 Roofing/Siding 4 05-27-2008 01:02 PM
Piece on bottom of toilet tank won't seal Squeeealer Plumbing 1 07-14-2005 08:13 PM
