How Do I Know My House AC Freon Is Low? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 03:19 PM   #1
How do I know my house AC freon is low?
I know we are going through a heat wave, but I need to know why my AC is not keeping up with cooling sufficiently. My themostat appears to be about 3, 4, 5 degrees higher than the set temperature. One possibility is low in freon. I want to know how to read the gauges that the service man would hook up to the compressor. I can keep the service man honest if I knew how to read the gauges. Can someone help please? Thanks.
PPang100 is offline   Reply With Quote
Old 07-21-2011, 03:45 PM   #2
JJboy's Avatar
You just need to read the gauges......easy like that........LOL
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-21-2011, 03:45 PM   #3
Rewards Points: 6,652
First thing is, what temp are you setting the thermostat at. Also, when was the outside unit & A-Coil on the inside unit last cleaned. Also, make sure drapes are closed in all rooms, outlets & switches, doors & windows do not allow air leaks, your attic access has foam weather stripping around the edge where the access panel closes, to not allow heat to enter the home. Also, what is the temp of the are at the nearest register & farthest register on the furnace/air handler.
Old 07-21-2011, 04:08 PM   #4
An old Tradesmen
Rewards Points: 7,332
Reading the gauges is easy. know what the readings mean is a different story. there is no one set of readings that means good.
The Following User Says Thank You to beenthere For This Useful Post:
PPang100 (07-22-2011)
Old 07-21-2011, 04:16 PM   #5
Rewards Points: 79
I had this problem recently and I haven't learned how to read gauges yet but there's another indication of your freon being low, or why your AC isn't cooling sufficiently. Check the evaporator coil that's installed in your ducting. It looks like a radiator with all the fins. Mine was freezing over. A few causes of this is first blocked fins, I cleaned it out gently with an air compressor and vacuum. Second is a blower that's running out of oompf which isn't that likely but I cleaned my blower fins from the 20 years of buildup. Third is low freon. It doesn't flow through the pipes well and ends up freezing the coils over. You can get an idea if this is happening if your condensation drain isn't draining, or if you hear a gurgling sound in this area (there shouldn't be any sounds coming from this part of the AC system). My return line coming from the coil was even freezing over outside of the ducting.
Once you figure this problem out it's a good idea to go through your attic or crawlspace/basement and looking at the ducts that are visible. Ensure they aren't kinked anywhere, and take some metal tape (we call it speed tape in the military) and seal all of your joints in the ductwork. Also don't close off too many vents throughout the house or there won't be enough airflow going through the ducts. In order to keep that coil from freezing, sufficient airflow has to keep running over it to take the coldness away. Another common problem is a blocked return duct, ensure there's no furniture within a few feet of the return duct/vent opening or the system can't draw enough air in to pump through your house. Also keep objects away from the Unit outside, keep it clean (a good spray with the garden hose works fine), and use pipe insulation over the supply line going from your ac unit outside all the way to your evaporator inside.
Dwillems is offline   Reply With Quote
The Following User Says Thank You to Dwillems For This Useful Post:
Old 07-21-2011, 04:29 PM   #6
Rewards Points: 1,216
If the unit has been doing the job all summer and now it's not keeping up maybe you should clean the coils outside, change the filter, close all drapes previously mentioned, and give the unit plenty of time . In this weather it will probably run mostly all day, we are at or close to design conditions so the least little thing not maintained will show up right now.
COLDIRON is offline   Reply With Quote
Old 07-21-2011, 05:13 PM   #7
This is sound advice. Also if it is 100+ in your area right now, it is possible that the unit may be running outside of it designed sizing conditions, the area I live in for example typically uses 95 as a design outdoor temp for sizing, and I have responded to many calls where this is the case. But, you definately want the outdoor coil, as clean as possible. I have been a tech for 12 years now and I can assure you my personal unit is very well maintained but did fall almost 2 degrees behind set point a few days ago when it was 104. So shut all power off to the condensing unit (outdoor unit) and clean the coil from the inside, forcing water outward. If at any point you begin to question what should be taken apart, or what not to touch, it would probably be worth calling a qualified technician.
tech95 is offline   Reply With Quote
Old 07-22-2011, 10:18 PM   #8
Thanks for the response. If no set reading can mean goof, then how does one tell if the freon is low?
Old 07-22-2011, 10:20 PM   #9
Excuse my lack on knowledge on home AC, but what is an A-coil?
Old 07-22-2011, 10:24 PM   #10
Thank you for being so helpful. I will save your mail for later use.
Old 07-22-2011, 10:26 PM   #11
Your advice is useful. I saved it for later reference. Thank you very much
Old 07-22-2011, 10:31 PM   #12
An old Tradesmen
Whats called super heat and sub cooling tells weather a system is low has a restriction or dirty coils.
Old 07-22-2011, 10:36 PM   #13
Dirty coil seems like a very common problem with AC not cooling properly. Thanks.
Old 07-23-2011, 12:05 AM   #14
I had a day this week where my AC ran full tilt but could not get the temp of the home under 77. The air out of the vents was a very cool temp the whole time - the outside environment I think was beyond the abilities of my home's insulation and the outside temp. Calling a tech to check your refrigerant is the only real way to know if you are lacking and preferably when the temp outside is 70+. I have, but since my AC is working relatively AOK I am low priority for them to get here to check the refrigerant levels.
Mrdippy is offline   Reply With Quote
Old 07-23-2011, 05:02 AM   #15
Rewards Points: 79
Its the condensor coil inside the ducts that transfers the cold to the air and heat to the refridgerant... Most of them are in the shape of an A to maximize surface area while still fitting in the ductwork
PPang100 (07-27-2011)
Tags
ac freon
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 02:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
