Old 12-22-2009, 04:54 PM   #1
DIY Apprentice
tripflex's Avatar
How do I know if i have a heater?
Alright so don't know much about HVAC but i'm not sure how to tell if i have a heater or not and how to test it. The A/C works fine, air handler blows great (had a bad capacitor, replaced and it works great), and being in Florida...never really had the need for a heater.
Anyways, how do i tell if i have one or not?
Mine is model: twg048a140b1
4 ton American Standard
On the outside of the air handler it has two boxes for the heater that say "Factory Installed" and "May Be installed in field", the "may be installed in field" box is checked.
Thanks for the help
EDIT: I would still like to know how to tell if i have one, but i just turn the air handler to ON instead of AUTO and it started blowing warm air.
SOOOO...it seems the problem here is with the blower being turned on. Now it could be in the unit itself or with the wiring of my thermostat.
There are 5 wires, red, green, yellow, white, and blue.
Only 4 are hooked up, red to RC (which is jumped to RH), green to G, yellow to Y/O, and white to W/B.
any ideas?
"How else am i supposed to build my tool collection and owe home depot lots of money? That's why I DIY"
2,200 SQ ft 3/2 Lake house with in-ground pool:
Help us help you by posting pictures with your question!
tripflex is offline   Reply With Quote
Old 12-22-2009, 05:10 PM   #2
the Musigician
DangerMouse's Avatar
can you just set it to 'auto' and turn the thermostat up higher? that should force the heat to come on.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 12-22-2009, 05:41 PM   #3
DIY Apprentice
tripflex's Avatar
DM
Tried that and the blower doesn't turn on...only way it turns on is when i set the fan to ON
Old 12-22-2009, 05:50 PM   #4
An old Tradesmen
Remove blower panel. And look to see if a heat kit is installed.
May have a bad board, relay.
Old 12-22-2009, 06:17 PM   #5
It was a dark and stormy
Yoyizit's Avatar
If a heater comes on, your electric meter disc will spin much faster.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
