How Do I Cut An Existing 5" Duct? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 12:40 AM   #1
how do i cut an existing 5" duct?
i need to cut out a 8 inch long piece of my 5" dia duct so i can put in a tee for a connection to a new register.
The duct is in between two joists. Should I try to cut the duct with a reciprocating saw, or are tin snips the best way?
big guy1 is offline   Reply With Quote
Old 03-07-2010, 03:08 AM   #2
jlhaslip's Avatar
Rewards Points: 1,090
Wouldn't it be easier to dis-assemble the duct and then cut the duct?
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 03-07-2010, 05:07 AM   #3
An old Tradesmen
Rewards Points: 6,588
Easiest way I know.
Hope that 5 inch goes to a bathroom, and you added another bath. And are running the new line to it.
Other wise, you aren't going to get much heat to where ever that tee will feed.
Install new vent/register into existing duct work? Jughead HVAC 11 12-09-2010 06:08 PM
How to add a new vent to an existing duct? tripower HVAC 3 09-20-2009 08:00 PM
Adding a stand alone wood furnace to existing duct work vtboy51 HVAC 1 04-01-2009 03:19 PM
Tapping into existing metal duct Mike_Atlanta HVAC 1 11-30-2007 01:07 AM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
