How Do I Convert My Furnace From Propane To NG? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 05:44 PM   #1
How do I convert my furnace from propane to NG?
I have a Consolidated Furnace mba 120 NH4R that I need to convert from propane to natrual gas. Any literature or guidelines out there to help me DIY?
DGRAY is offline   Reply With Quote
Old 06-22-2009, 06:22 PM   #2
Drywall contractor
Rewards Points: 1,070
I'm no HVAC expert, but I believe it's a matter of changing the orifice in the gas valve. I REALLY don't think it's a DIY project though. I'm sure you'll get more replies.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-23-2009, 08:13 AM   #3
Thanks.
Thanks.
Old 06-23-2009, 11:02 AM   #4
Tired & Dirty
Rewards Points: 83
Yes, you will need to convert your gas valve or replace it if conversion kit not available, also change or drill your burner orfices to correct BTU rating. Reset gas pressure with manometer to natural gas w/c specs.
evapman is offline   Reply With Quote
Old 06-23-2009, 11:23 AM   #5
Thanks EVAPMAN
Old 06-23-2009, 02:43 PM   #6
You may have problems finding a kit for this furnace. Consolidated Industries went out of business years ago. The valve spring you should be able to find. You may be able to find someone who can gauge and drill the orifices for you.
SKIP4661 is offline   Reply With Quote
Old 06-23-2009, 06:11 PM   #7
Do you think I can get away with just drilling out the oriface?
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 03:57 PM
Purchased Amana 93% Furnace - Convert from LP back to NG Tech08 HVAC 7 02-18-2009 07:46 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Cozy Propane Furnace Start up Noise NJ Gimo HVAC 7 01-01-2007 10:06 AM
