How Do I Add Water To My Boiler System? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 06:29 AM   #31
Rewards Points: 610
you may have to drain system to install by pass however, not much water ...once you fill system shut off the new bypass valve..this will place pressure relief back in play...actually you never take it out of play as you are leaving it in the system at all times...you will notice it releive if you allow the feedwater to pressurize the system over set point of relief which is likely 30psi. i.e. install tee in supply water line before existing regulator and tee in system line after regulator and install valve between tees..this will give you a means to manually fill system ..once you get up to desired pressure you mist shut valve..the relief is always subject to system press.
BTW you should set press at 13 - 15 lbs max
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
Quackerjack (11-26-2012)
Old 11-26-2012, 06:38 AM   #32
Items wanted: Time
Rewards Points: 150
Like this here, only with quarter turn ball valves.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
Old 11-26-2012, 12:12 PM   #33
Quackerjack's Avatar
Ah, okay -- I understand now! I can do that. Do I need any particular type of quarter turn ball valves since I'm going from copper to iron?
Heh, now it makes me think maybe I can also replace the pump and those pressure valves myself ... any recommendations? and would they (particularly the pump) be re-useable when I eventually get a new boiler or would it be a waste?
Quackerjack is offline   Reply With Quote
Old 11-26-2012, 12:25 PM   #34
Items wanted: Time
Rewards Points: 150
You should put in dieelectric unions with high temp gaskets
Old 11-26-2012, 10:27 PM   #35
Temporarily ...Attach garden hose to boiler drain and to water supply ..you may need adapter to reconfigure hose to fit......open water supply then open drain slowly to back feed and pressurize system until water bleeds from upper rads. This should get you going temporarily until you can replace defective valve(s).
NOTE...DO NOT LEAVE HOSE ATTACHED TO DRAIN....IT WILL EXPAND AND BURST IF LEFT EXPOSED TO THE HEAT
This worked beautifully. All radiators now have heat! Next step is to either replace the old valves myself or bite the bullet and get a company to replace the whole thing including boiler and pump. Thanks Techpappy and everyone else for your input!
PS. I do still have a question about installing a new pump. Would an eventual new boiler have the pump already mandatorily included as part of it or is it a separate part? I don't want to waste time and money on a new pump if I may end up replacing the whole thing within 6 months and then have to throw out the new pump I just installed. Also, is the clicking/rattling which is apparently a sign of "the bearings going" a major issue that needs immediate attention?
Old 11-27-2012, 12:15 AM   #36
Rewards Points: 616
as we said get water in it ......:thu mbsup:
carmon is offline   Reply With Quote
Old 11-27-2012, 05:13 AM   #37
An old Tradesmen
Rewards Points: 6,570
New boiler will come with a new circulator.
Old 11-27-2012, 10:20 AM   #38
Rewards Points: 610
replace pump if not replacing boiler..current pump doesn't sound like it will last the winter
problems with Grundfos UPS 15-42F pump and my boiler heating system Hexar HVAC 21 10-31-2011 05:44 PM
Cast iron vs mod/cons rickmay HVAC 46 10-21-2011 04:42 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
