-   -   how did this tale start? (http://www.diychatroom.com/f17/how-did-tale-start-166399/)
FISH96 12-13-2012 06:49 PM
i just finished a very spirted discussion concerning the topic, "hot water freezes faster then cold water."
i tried every thing i know from BTU content, latent heat, removal of heat,
etc., etc.,. could not convince these chaps they are off the tracks on this item. Their thoughts were molecular distance in the hot water.
Have any of you had this crazy-ness thrown at you. they are very steadfast in this belief. I am quite amazed at this thinking.
Daniel Holzman 12-13-2012 07:00 PM
I have been hearing this story for at least 25 years, along with a variety of other misplaced physics concepts. I have run into some very smart people who believe stories which to me seem absurd (earth is 12,000 years old, we never made it to the moon, the World Trade Center was not destroyed by airplanes etc.). I occasionally argue, but I have never dissuaded anyone from firmly held beliefs. The simplest way to refute the hot water story is to put two trays of water in the freezer, one hot and one cold, and see which one freezes faster. But even physical proof may not carry the day.
ben's plumbing 12-13-2012 07:24 PM
dan gets my vote.....do the simple test hot and cold water in freezer see who freezes 1 st.....at least you will know forget what others think....ben sr
hvac benny 12-13-2012 07:44 PM
You're both right. Hot water can freeze faster than cold water- its called the Mpemba effect. There's more to it than simple thermodynamics, and it's not really fully understood, but it is possible.
danpik 12-14-2012 06:32 AM
Several years ago I owned a building that had the hot and cold water lines feeding an upstairs appartment going thru a stairwell area. This area was not heated very well and thus the pipes froze once in a while. 9 times out of 10 it was the hot water pipe that was frozen and not the cold. These pipes ran up the wall about 2" apart. Same length, exposure, material etc. Tenant told me about the hot freezing before the cold "myth". did not know what to say so kind of shrugged it off. After giving it some thought I determined why the cold was never frozed as much as the hot. More cold water was being used at night than hot. toilets flushing etc. I have heard this "myth" other times and the only "credible" explanation is that if the water is heated enough it removes more of the oxygen out of it. I don't know.
Sounds like Jamie and Adam need to work on this one
COLDIRON 12-14-2012 07:08 AM
I'll go with Dan's test and bet on the cold freezing first. I am sure in the Lab environment anything is possible . Humidity, air pressure , vacuums, induction of chemicals , etc, etc.
In the Lab or a test environment I'm out.
TheBobmanNH 12-14-2012 11:25 AM
I've also heard the other way - that cold water boils faster than hot water.
beenthere 12-14-2012 03:23 PM
Distilled water doesn't boil. Anyone can do the test at home to prove it.
drtbk4ever 12-14-2012 03:49 PM
I thought Jamie and Adam already did this one. I think they proved that hot does NOT freeze faster than cold. But I could be wrong. I'll google it later when I have more time.
All I know is they used hot water to flood the ice rink when I was a kid. Some said it was because hot water froze faster. But I argued the hot water in fact melted a bit of the underlying layer and froze to a more even surface. But that is a topic for another day.
Missouri Bound 12-14-2012 07:45 PM
danpik I believe has the most logical answer. I've seen it time and time again where a hot water pipe froze and the cold did not. Maybe the hot pipe will condensate first...then as a result freeze?? :eek:
Bondo 12-14-2012 08:21 PM
Ayuh,.... It started with Aristotle,.... a couple hundred years, BC....
I remember it from 6th grade science class, 1967...
jagans 12-14-2012 09:16 PM
"I got some, Ocean front property in Arizona, from my front porch you can see the sea, I got some, Ocean front property in Arizona and if you buy that ill throw the Golden gate in free"
George Strait
Missouri Bound 12-14-2012 09:23 PM
How about..............."the hot water pipes tend to build up with sediment over time, thus decreasing the volume of water in any given section. Less water, shorter time needed to freeze."
beenthere 12-15-2012 03:49 AM
One of the last things most people o before going to bed is brush their teeth. And most people use cold water to rinse. So the cold water line is kept warmer and doesn't freeze, while the hot water pipe hasn't had any new hot water ran through it for an hour longer then the cold water pipe.
Starlight 12-15-2012 04:38 AM
I've always heard that the hot water freezes first because there's less of it. Meaning that people put the same VOLUME of water outside to test, the hot freezes first because there is less WEIGHT of hot water than cold. If people would put the same WEIGHT of hot & cold out the cold would freeze first. The difference in weight of the same volume of hot & cold isn't that much - but it's enough to make a difference.
