How To Determine ROI Of Efficient Versus Regular Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 09:02 AM   #1
How to determine ROI of efficient versus regular furnace?
We're planning to replace our furnace. We were offered two different replacement furnaces. The specs I was given are these:
#1 (regular): 90,000 Btu / natural venting / 80% efficient / multi-speed 1400 CFM blower / 115 volts / 15 amps
#2 (efficient): 95.5% efficient / direct venting / 3 stage / 1400 CFM blower / gas fired furnace / 80,000 Btu input -- 74,000 Btu output
#2 is, of course, more expensive. Suppose
- I know how much gas I have used every month for the last year or two.
- I assume that I will use the same exact amount every year.
- I assume today's gas price
Are there formulas that would let me compute when I will pay off the difference between the two furnaces?
Thanks much!
ilyaz is offline   Reply With Quote
Old 12-23-2009, 10:19 AM   #2
An old Tradesmen
Rewards Points: 6,940
Are they putting in the same size furnace as is there now. If so, you could use as much or more gas with a new furnace. Newer furnaces need to move more air then older ones did.
Have a load calc done to see what size furnace you need.
A 90,000 BTU input 80% efficient furnace has an output of 72,000 BTUs.
A 80,000 BTU input 95% efficient furnace has an output of 76,000 BTUs.
Here is a site that you can use to compare operating cost.
Old 12-26-2009, 09:57 AM   #3
tk03's Avatar
Rewards Points: 150
The load calc can mean more on increasing the fuel savings than the efficiency. Need to proper size the unit first than look at efficiency.
See link below for FAQ
http://www.comfort-calc.net/faq.html
tk03 is offline   Reply With Quote
Old 12-26-2009, 01:27 PM   #4
Home Air Direct's Avatar
Here is exactly what you are looking for.
http://www.acdoctor.com/cooling_calculator.php#heating
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 12-26-2009, 01:52 PM   #5
[B]#1 (regular)
[B]#2 (efficient)
If you assume no noticeable difference in utility bills with either the old furnace or #1 or #2, and I think that is a reasonable assumption, the difference in price between #2 and #1 will never be paid off unless #2 is much more reliable than #1 and the replacement parts cost is much less.
The control board price is a good place to price-check; they are costly and fragile.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
How to determine best size and type for replacement furnace ilyaz HVAC 7 12-22-2009 10:55 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Trying to determine the age of my furnace quickly Ferlea HVAC 1 06-29-2008 10:11 AM
