How Critical Is That Type-B Vent Fittings Lock Together - HVAC - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 12:07 PM   #1
Rewards Points: 1,062
Question
how critical is that type-B vent fittings lock together
type-B fittings are far from perfect -- sometimes they bend and deform in shipping and they won't click/lock male to female.
i was wondering how absolutely critical is that they click, if they do hold in place nonetheless. e.g. i have a tee and an elbow below it on the bottom of a 16 ft chimney liner. the opening was really tight to fit the tee/elbow composition in and we had to set it in before sliding the chimney liner down. once we slid it down, we finagled a little to get the sleeve female to fit onto the tee male and finally got it in but there was not much we could do it to get it to lock. but the joint is firm because there is the weight of 16 ft of vertical liner + chimney cap above it so it's not going anywhere but was wondering if this may present a leak or something.
the chimney is used for a gas water heater and a gas radiator boiler.
Old 09-26-2011, 06:36 PM   #2
An old Tradesmen
Rewards Points: 6,116
Good question. Now if only some one can come along with a good answer.
Old 09-26-2011, 08:42 PM   #3
I would think that a good fit would be critical. An air gap in the fittings would let the vent gas run along the outer wall of the pipe. A lot of combustible clearances are not paid attention to because of the double wall construction. Any joint not locked in properly may cause the pipe the be a single wall, and a fire danger.
Master of Cold is offline   Reply With Quote
Old 09-27-2011, 07:15 AM   #4
Rewards Points: 1,214
Maybe you can use a little dish soap with water and a brush once it's together the soap and water will dry up soon after that and not effect the vent. I would say locked tight because it's such an important item regarding life and safety.
COLDIRON is offline   Reply With Quote
Old 09-27-2011, 07:39 AM   #5
the male IS inside the female, it just won't lock. it's not like it's half way in or there is a crack in the joint or something...
Old 09-27-2011, 08:38 AM   #6
Rewards Points: 150
Over time expansion and contraction could cause the fittings to seperate creating a very unsafe situation. If locked that won't happen.
josall is offline   Reply With Quote
Old 09-27-2011, 09:05 AM   #7
If you have to screws and metal tape.
Old 09-27-2011, 06:18 PM   #8
Take some bricks out for better access. One guy on the roof turning the pipe and the other holding tight from below. If that doesn't work then the joint will need to be screwed in 3 places to keep it secure.
The Following User Says Thank You to Marty S. For This Useful Post:
amakarevic (09-27-2011)
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 06:21 PM
Type B Vent Question NGuy HVAC 4 08-08-2008 09:04 PM
Microhood vent location, diameter, duct type? pcampbell Appliances 6 03-20-2008 07:07 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
