How To Connect Bath Fan Exhaust Pipe Fittings - HVAC - DIY Chatroom Home Improvement Forum
Old 04-03-2012, 02:08 PM   #1
Rewards Points: 1,062
Question
how to connect bath fan exhaust pipe fittings
what are the proper/recommended ways to connect fart fan exhaust pipe fittings, 3 and 4":
1. just aluminum tape is fine
2. clamp rings
3. 1/2" machine screws hex head
4. something else
5. some combination of 1-4 above
this is a concern of relatively low relevance as the application seems kind of low duty but i meant to ask for advice anyway.
thanks
Old 04-03-2012, 02:13 PM   #2
Just a DIY guy
I'm interested to see the answers, as I've wondered this myself, and have a fan I will be installing in the next week or so.
In the past I've used mastic and 1/2 inch sheet metal screws (not machine screws), and foil tape on top. That's kinda like holding up your pants with a belt, suspenders, and glue, but I'm sure it will never fail!
These are mastics
http://rcdmastics.com/6-mastic-duct-...e-sealant.html
http://www.homedepot.com/h_d1/N-5yc1v/R-100396972/h_d2/ProductDisplay?catalogId=10053
M3 Pete is offline   Reply With Quote
2" pipe on above sink in wall rusted out in a spot bryanp22 Plumbing 9 02-23-2012 09:29 PM
How do I cap off an exhaust pipe that is no longer connected? tremaine5 Plumbing 7 07-29-2011 02:41 PM
Securely join ABS or PVC pipe to fittings? goofy Plumbing 1 07-24-2010 12:12 AM
Portable AC exhaust pipe length delgriffith HVAC 1 07-18-2008 06:19 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 09:16 PM
