How To Connect A 95% Funace Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 08:56 AM   #1
how to connect a 95% funace vent
how can i install a 95% afule furnace to a stanard chimney with a old furnace that is that is about 65% i would like to use the higher efficient unit .
mr3032 is offline   Reply With Quote
Old 01-31-2010, 09:48 AM   #2
An old Tradesmen
Rewards Points: 6,112
You can't legally.
Unless you run a flue pipe all the way up through your chimney. And then you can't have your water heater or any other natural draft appliance venting in the same chimney.
It must be vented with PVC/ABS(depending where you are may not allow ABS)plastic pipe.
A 90% vented into a regular chimney would have around 5 to 12 gallons a day of condensate forming in the chimney, and destroy the chimney.
Old 02-02-2010, 11:46 PM   #3
Originally Posted by beenthere View Post
You can't legally.
So the best option that i would have is to use a standard 80% eff unit for this type of installation which i have
Old 02-03-2010, 12:10 AM   #4
An old Tradesmen
Or side vent the 90%. That is the most common method.
Just have to check that your chimney isn't too big for the water heater only.
Old 02-03-2010, 12:25 AM   #5
Rewards Points: 256
whats the cuttoff between high efficiency and regular 80 -90 ??
oldrivers is offline   Reply With Quote
Old 02-03-2010, 12:39 AM   #6
An old Tradesmen
Basically 80% is standard, or mid efficiency and non condensing.
And anything 90% or above is high efficiency, or condensing.
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
Connect to cast vent in slab Joe F Plumbing 2 09-14-2008 06:33 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Plumbing Vent size recommendations rlhed Plumbing 4 07-31-2008 01:01 AM
