How To Connect 2 Thermostats To One - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 10:25 AM   #1
how to connect 2 thermostats to one
i have a new home in new york and have two thermostats for it ,one controls the heat up stairs and one for down stairs . i want to know how to control both up and down just from the one upstairs if possible..the thing is that the folks who rent from me downstairs just abuse the thermostat and with oil prices sky high i would like full control over this issue.
lerknitty@optonline.net is offline   Reply With Quote
Old 10-04-2008, 11:01 AM   #2
Put a meter on the flow of oil and charge them for it. Nothing like having to put out money as a deterrent to modify ones behavior.
Or just increase the rent and tell them it because Congress won't let us drill for oil.
You will run into the socialist laws of New York if you try to mess with their environment. I am sure that you could be sued if you did that.
Marvin Gardens is offline   Reply With Quote
Old 10-04-2008, 02:03 PM   #3
Speedbird's Avatar
This is more of a legal problem than an engineering solution. If they have a lease then you had better understand exactly what it says regarding the HVAC or you will be in a world of hurt if deny them something they are legally entitled to receive.
Speedbird is offline   Reply With Quote
Tags
thermostat help
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Programmable backlit thermostats invertedflight HVAC 4 03-27-2008 01:47 PM
How to connect a Digital Thermostat jfgagnon Electrical 2 05-10-2007 12:01 PM
Adding a phone line to an older connect point cramsmith General DIY Discussions 3 11-23-2005 11:35 AM
