How To Confirm 2nd Stage Burner Working? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-28-2008, 11:21 PM   #46
Originally Posted by beenthere View Post
It depends what your temp rise is.
If your temp rise is low. Then it could cause condensation in the primary heat exchanger. And the primary is not designed to have condensation happen in it.
2 stage units are a couple % less efficient in first stage to begin with.
So your just a bit less efficient yet with an under fired first stage.
So instead of being at 92 or 93%, you may be down to 89 or 90% in first stage.
Check your temp rise.
Then do the math.
(temp rise times 1.08) times CFM equals BTU output.
See what it says.
Don't even go there Been! The pro forum is still arguing that point and I think the thread post count has exceeded 4789!
LOL!
hvaclover is offline   Reply With Quote
Old 12-28-2008, 11:28 PM   #47
An old Tradesmen
Rewards Points: 8,168
LOL...
But it was a good thread.
Did you check out the evacuation thread yet.
Old 12-28-2008, 11:34 PM   #48
LOL...
No. What pro forum was it in?
Old 12-28-2008, 11:39 PM   #49
An old Tradesmen
Pro tech.
Old 12-29-2008, 06:11 PM   #50
Hvac Pro
yuri's Avatar
Rewards Points: 384
A fella can never have too many tools! or toys. You may need it someday if you have a pressure switch problem or other issues. The Testo one is especially good for pressure switches.
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 06:30 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
single stage and dual stage heat pump vshaynes HVAC 1 10-07-2008 09:18 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
