Old 07-02-2012, 07:29 AM   #1
how cold should low pressure line be
I was weeding near my York condenser unit (YCJF42S41S1, not a heat pump) and felt the low pressure line (unit was running at the time). It wasn't very cold and no condensation (quite humid lately). House is keeping cool (set to 77* during day) in 98* weather but I'm wondering if freon charge might be off?
Condenser YP9C080C16MP with Aspen coil and thermal expansion valve.
Does the TXV "compensate" for off-pressure charge?
bob22 is offline   Reply With Quote
Old 07-02-2012, 07:48 AM   #2
biggles's Avatar
beer can cold...as long as that liquid line is filled from 3-4 rows up out on the condenser that is the state that the TXV looks for to operate(if you have it might be cap tubes).if the liquid level(charge) is low that liquid seal where the LL starts coming out of the condenser is changed seeing flashing and gas burps into the TXV....somewhat like a garden hose spray.so as the liquid is metered out into the evap the pressure drops as so does the temperature to give you 40F.typical evap is 18F drop on return air vs supply air taken at the air handler,with 10F rise on the air into and out of the condenser.sounds like it needs a tweek with questionable charges effecting the unit run time(longer) trying to make setpoint
Old 07-03-2012, 01:17 PM   #3
I measured temp at a register close to the unit, 63*. Temp inside house set for 77* so I assume intake air would be close to that.
Do I have to measure within the duct work leading just out of the unit or is a register 10' away ok?
Old 07-03-2012, 01:43 PM   #4
biggles's Avatar
right on top of the A coil plenium box and at the filter on the return if you want to get that 18
Old 07-03-2012, 02:12 PM   #5
Thanks; I see what holse I can find to poke in a thermometer.
Old 07-03-2012, 08:18 PM   #6
biggles's Avatar
nail and a hammer just above that A coil into the duct work
Old 07-04-2012, 05:52 AM   #7
An old Tradesmen
Make sure your above the A coil.
Old 07-04-2012, 11:46 AM   #8
retired elect/hvac/plumb
plummen's Avatar
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Replaced cold cartridge, now hot and cold both have low pressure. zing Plumbing 5 05-28-2012 09:57 PM
Part2-Rumbling pipes and leaking pressure relief valve Homerepairguy Plumbing 9 04-24-2012 04:49 AM
cold water pressure low in new faucet tndale Plumbing 1 03-16-2011 03:15 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
