How Close Can I Build Walls To My Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2012, 10:01 AM   #1
How close can i build walls to my furnace?
I am hoping someone can help me out here please. I am looking at how close i can build walls to the furnace. the walls will be to the back of the furnace and the left side. I have looked all over to see if there are codes for it and cant seen to find anything. I am just drawing up my plans to see how much room i have for my shower.i am located in Calgary, Canada. Its a Trane xr90 installed into a new house 3 years ago.
thanks for your help.
hello18 is offline   Reply With Quote
Old 02-02-2012, 10:30 AM   #2
have you tried the trane website?
Old 02-02-2012, 10:35 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
You can pretty much butt the wall (by butt I mean give around 2 inches of room) to the unit on any side that the furnace except the service side. That has to be completely accessible.
Vertical closet units barely have any room in them on three sides.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 02-02-2012, 12:03 PM   #4
this is what Trane just sent me. i am going to give 4 inches on the back 6 inches on the side and leave the front at 4 feet which i have right now.
MINIMUM CLEARANCE FROM COMBUSTIBLE MATERIALS FOR
UPFLOW/HORIZONTAL AND DOWNFLOW/ HORIZONTAL FURNACES
UNIT LOCATION
FURNACE SURFACE VERTICAL
SIDES 0"
BACK 0"
TOP 1"
FRONT 3"
VENT 0"
NOTE: CLEARANCE REQUIRED AT TOP OF PLENUM IS 1"
Old 02-02-2012, 12:25 PM   #5
MarginallyQualified
Rewards Points: 2,464
If the duct will be insulated (and it should be)... then allow for that too.
R8 is 3" thick.
Old 02-02-2012, 12:42 PM   #6
thee inch front clearance does not mean to an immovable wall but to an access that readily allows you to get to the moving parts for service.
That is usually 24".
hvac5646 is offline   Reply With Quote
Old 02-02-2012, 12:44 PM   #7
Old 02-02-2012, 12:44 PM   #8
Rewards Points: 14,312
Not sure how your going to attach 5/8 fire rated sheetrock to the inside to meet code if those walls are sitting that tight.
Old 02-02-2012, 01:16 PM   #9
THIS!!
it's 30" down here.
Thanks.
Old 02-02-2012, 02:45 PM   #10
Do i have have to put fire rated sheet rock inside the new utility room behind the furnace? i was going put nothing up
Old 02-02-2012, 02:46 PM   #11
Depends. The local authority usually does not quibble over six inches as long as it can be demonstrated a service man can make the repairs .
Hell, Uncle used to weigh 360 and he got into clearances as small as 18".
Course, he's slimmed down a lot.
Old 02-02-2012, 02:47 PM   #12
I didnt understand why they even have that on the paper.
i have over 40" for the front of the furnace incase i need them to service it.
Old 02-02-2012, 05:10 PM   #13
I think it was a typo. Supposed to be 30" not 3" in front.
Old 02-02-2012, 05:11 PM   #14
Called my city office and they said you need 30" in front of the furnace. he also said it would be nice to have 6 inches on each side but was not mandatory
Old 02-02-2012, 05:32 PM   #15
[QUOTE=Marty S.;842469]I think it was a typo. Supposed to be 30" not 3" in front.[/QUOTE
Just looked and said 3 but that is for sure wrong
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Wanting to build heavy shelves on plaster walls (apartment) mtr_can Remodeling 1 08-15-2011 04:27 PM
How much space between furnace and walls? DangerMouse HVAC 8 07-31-2010 01:04 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
