How To Clean Bloower Compartment - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 08:40 AM   #1
How to clean bloower compartment
I opened up my blower compartment and it's pretty dusty in there, and even has some hairs in there from the air circulating. I thought the filter would catch all of that, but I guess not.
Should I clean this out? If so, what's the best way. I was thinking with a brush attachment on the end of a shop vac, but I don't want to hurt anything, especially the circuit board. Any thoughts?
Thanks.
humdinger0102 is offline   Reply With Quote
Old 03-16-2011, 11:10 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I'd have to think that you have an air leak some where in the return chase and/or that the system has been run without filters here and there.
You are more than likely also going to have a dirty supply plenum which is an easy clean. You can pull of a duct or two and take a vacuum to the inside of the plenum.
Take a small paint brush for (manual dusting dust) and a dust pan to the inside of the unit and be very careful around all wires. You can also take your shop vac to it, just be extremely careful and make certain the power is off to unit which it should be once you remove the door but I'd still shut off the breaker to be on the safe side.
Doc Holliday is offline   Reply With Quote
Old 03-16-2011, 11:12 AM   #3
And have the evaporator coil cleaned, it's gotta be dirty/clogged up too which means your system is not efficient and is struggling. Higher electric bill too.
Old 03-16-2011, 12:30 PM   #4
Still Learning
It might be overkill but this is what i do... Disconnect the wires to the control board and pull out the whole blower assembly. If you dont know how to wire up a control board then simply write everything down as you pull wires off. That will allow you to clean the whole inside of the blower compartment without too much trouble. You can even carry it to the garage and blow it out with a compressor.
thehvacguy is offline   Reply With Quote
Clean oil off of tools, also clean the inside of a compressor capslock Tools 1 12-23-2009 11:36 AM
How often do you clean your Paslodes Bearcreek Tools 1 08-24-2009 09:00 AM
Keeping Hardwood/Bamboo Flooring Clean? brandon272 Flooring 2 07-08-2009 09:39 AM
How to clean porcelan tiles? Talking Dreams Tiling, ceramics, marble 4 02-08-2009 09:01 AM
Leaking main drain clean out plug bucksone Plumbing 1 01-10-2009 07:42 AM
