How To Change The Master-slave Control Model - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 05:38 PM   #1
How to change the master-slave control model
The HVAC control system in my house follows the master-slave model. I would like to change it and make all 3 zones completely independent.
How should I do? Will this would be a big project?
Thanks a lot
skyscape is offline   Reply With Quote
Old 08-20-2012, 06:32 PM   #2
An old Tradesmen
Rewards Points: 7,414
Would need brand and model number of the zoning system, and the thermostats.
Old 08-20-2012, 08:53 PM   #3
The model number of the zoning system is: EWC controls INC. Model: EWC-ST-3D ultra-zone control panel
The mudel number of the thermostats is: Braeburn system, model: 5000
Old 08-20-2012, 09:00 PM   #4
An old Tradesmen
Sorry, not familiar with that model.
Old 08-20-2012, 09:23 PM   #5
Any idea what should I do to find out? Like where to find the contractor?
Will this be covered by the home appliance insurance?
Old 08-21-2012, 04:18 AM   #6
An old Tradesmen
Probably won't be covered, since its working. Warranty usually only covers things that don't work.
May want to contact EWC, and ask them if it can be changed, and find out if they can send you the install manual for that panel.
Old 08-21-2012, 07:34 AM   #7
Houston204's Avatar
Rewards Points: 556
As Beenthere has posted an alternate EWC control would be the least expensive solution because of the cost of new damper installation.
The new Ultrazone 4 looks like it will give you independent control.
http://www.ewccontrols.com/acrobat/090375a0221.pdf
Houston204 is offline   Reply With Quote
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Master Bedroom very warm ks-man HVAC 34 11-03-2011 09:42 PM
Change 2nd Vent in the master to a Return? Joey-D HVAC 7 05-24-2011 06:28 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
