How To Change Gas Valve On Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 03:05 PM   #1
How to change gas valve on boiler
I know I've posted about this a number of times already.
We had someone come look at it he said it was that the gas valve needed replacing. He was supposed to do the work today but never showed up?
I'm mechanically inclined with alot of things so if it's basic it shouldn't be a problem.
Is it a big deal replacing that valve?
Carloscda40 is offline   Reply With Quote
Old 03-07-2009, 03:20 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,136
Yes. There are different types of gas valves depending on the method of opening etc. As well as the dangers of leaks/explosions/liabilities/family safety etc it is best to get a licensed gas fitter to do it.
Old 03-08-2009, 09:08 PM   #3
HVAC / Plumbing
Some things You will need to know....the voltage, does it open in stages or all at once, inlet outlet size. how many BTU'S are needed for the boiler. If you install this. check for any gas leaks & the operation..
Be safe !
kenmac is offline   Reply With Quote
Old 03-08-2009, 11:09 PM   #4
Well sometimes you just has to call a pro.
I'll put some calls in tomorrow, thanks again.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
central heating boiler leacking from relieve valve ladybreaker Plumbing 3 01-07-2009 01:37 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
