#1 |
Mechanical Engineer
How can you tell when the HSI is ready to go?
I've got a Carrier Weather Maker 9000 58MXA060 (60,000BTU's?) I've had some minor problems with the pressure switch so far. Loose wire, then a new switch. All seems to work fine now. I've ready a few posts about the HSI going bad. Are there symptoms to indicate imminent failure or does it just crap out? Then you hope you have one on hand or they are easy to come by.
By the by, the HSI and the igniter are the same thing, right? Last edited by gshock; 11-07-2007 at 12:18 PM. Reason: ... just because... |
#2 |
scotch on the rocks
you need an ohm meter, unplug the HSI and take a reading across it, if more than 200ohms its about to crap up.
#3 |
Mechanical Engineer
How can you tell when the HSI is ready to go? |
| Display Modes | |
| New construction ready for roofing... | MLO | Roofing/Siding | 2 | 11-03-2007 03:46 AM |
| Ready to lay laminate... Question... | KUIPORNG | Flooring | 6 | 04-13-2007 03:17 PM |
| Getting ready to tile bathroom floor, question | J187 | Flooring | 4 | 06-06-2006 01:31 PM |
| Getting ready for the bathroom subfloor project scheduled for this weekend... | tallycat77 | Flooring | 8 | 07-10-2005 11:50 PM |
