-   -   How can you tell when the HSI is ready to go? (http://www.diychatroom.com/f17/how-can-you-tell-when-hsi-ready-go-13152/)
gshock 11-07-2007 11:18 AM
I've got a Carrier Weather Maker 9000 58MXA060 (60,000BTU's?) I've had some minor problems with the pressure switch so far. Loose wire, then a new switch. All seems to work fine now. I've ready a few posts about the HSI going bad. Are there symptoms to indicate imminent failure or does it just crap out? Then you hope you have one on hand or they are easy to come by.
By the by, the HSI and the igniter are the same thing, right?
hvactech 11-07-2007 04:54 PM
you need an ohm meter, unplug the HSI and take a reading across it, if more than 200ohms its about to crap up.
gshock 11-08-2007 07:19 AM
Great. Thanks for the tip.
scorrpio 11-09-2007 02:07 PM
HSI is one type of an ignitor. There are others (i.e. spark)
