How Can I Vent A Bathroom Exhaust Fan Out Of The Window Without It Looking Hideous? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 05:13 PM   #1
How can I vent a bathroom exhaust fan out of the window without it looking hideous?
I can not break the outer wall. I must vent thru the window. I'm considering either an in-window fan, like this one, but am unsure how to run power to the fan while still allowing the window to operate, or a traditional ceiling fan, running the duct work above the ceiling and out the window, but I can't imagine an attractive way to pull this off.
The window is a typical double hung vertical slider. And, if need be, I can remove the glass as I am the homeowner.
Again, I'd like full functionality of my window and have it look good.
mizrachi is offline   Reply With Quote
Old 12-01-2010, 05:55 PM   #2
KemoSabe
loneframer's Avatar
Originally Posted by mizrachi View Post
Why not just open the window when ventilation is necessary?
loneframer is offline   Reply With Quote
Old 12-01-2010, 06:07 PM   #3
Because I'd be too visible . The bathroom is on the ground floor of an apartment building facing the courtyard. Tenants above and opposite this window would have a direct line of sight to me in the shower, on the toilet, at the sink, etc.
Old 12-01-2010, 06:56 PM   #4
Rewards Points: 1,596
Why can't you break the wall? It would cost more up front, but a ceiling mounted fan ducted through the wall would look better and likely perform better.
bob22 is offline   Reply With Quote
Old 12-01-2010, 06:58 PM   #5
the building wont allow it
Old 12-01-2010, 06:59 PM   #6
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I would just bite the bullet and make a hole in the wall, vent it like a dryer. Depends what's above of course, if it's an attic then there would be no wall to vent out of, but you could vent out the soffit which will be even easier depending on how the roof slope is.
edit: oh nm, missed the part about the building not allowing it. (guessing it's a condo or rental?)
Old 12-01-2010, 07:01 PM   #7
How can they not allow it? Isn't there a building code on ventilation that putting in the fan would put them in compliance?
Old 12-01-2010, 07:04 PM   #8
KemoSabe
loneframer's Avatar
Ventilation fans are not required if there is an operable window.
Old 12-01-2010, 07:05 PM   #9
KemoSabe
loneframer's Avatar
I'd get a gym membership and some nice candles.
Old 12-01-2010, 07:08 PM   #10
good one! I was thinking the same kinda thing.
Old 12-01-2010, 07:13 PM   #11
Rewards Points: 282
That's nuts. If the landlord refused to supply a vent fan in the bathroom I'd be looking for another apartment. Of course I guess apartments are in short supply in some locales.
Jim F is online now   Reply With Quote
Old 12-01-2010, 08:14 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 2,268
The OP is the homeowner. Must be a Condo and they won't allow any changes to the outside of the bldg for cosmetic reasons.
Tags
bathroom , exhaust fan , vent , window
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom vent directly over a rafter Kirgan Roofing/Siding 6 03-11-2009 01:30 AM
Venting bathroom vent thru dryer duct jredrocker HVAC 2 09-27-2008 10:25 PM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
2 bathroom exhaust fans to one outside vent pipe? CGofMP HVAC 2 03-25-2005 09:45 PM
