How Can I Tell How Old A Boiler Is? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 07:01 PM   #1
How can I tell how old a boiler is?
I have a Burhman steam boiler, it was here when we bought the house 3 years ago. I am curious on how old it is? I don't see any date on it, can I tell by the serial number? Thanks guys. It's working fine, I am just curious to know how old it is.
helpless handyman is offline   Reply With Quote
Old 01-12-2009, 07:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
Post the model and serial #. Usually if it is gas fired you can find a date code on the gas valve. ie 9538 = 1995 38th week . Try find such a # on the backside of the cover of one of the controls etc.
Old 01-12-2009, 08:09 PM   #3
Home Air Direct's Avatar
This really is no help, but while looking for a Burnham nomenclature guide, I ran across this and several other similar sentiments from professionals.
"Well, I just had an inspection over the weekend with the same situation. I called Burnham to determine if there was a way in interpret the serial numbers and they said they don't have any way to do that. In fact, their response was, "There is no rhyme or reason for their numbers but you can call us with a serial number and we can tell you when it was shipped if it isn't an obsolete unit".
Good luck.
Jay
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 01-12-2009, 08:25 PM   #4
Okay, I found the date. A1983, so I am assuming Aprilof 1983, hmmmmm 25 yrs old. Is this consider old for these type of steam boiler? I have heard they last pretty long, but then again 25yrs is pretty long. Should I look into replacing it in the Spring? Open for suggestions .
Old 01-12-2009, 08:44 PM   #5
Hvac Pro
yuri's Avatar
They should last for a LONG time if properly maintained by someone who understands steam boilers. It may have a lower water cutoff control which should be cleaned/tested once a year. I would do it now as that is a VERY important safety device. As well as testing the burner and other controls/fill valve etc.
Old 01-12-2009, 09:26 PM   #6
JohnH1's Avatar
Thumbs up
Low water cutt off.
Cleaned once a year Flushed and/or tested once a week
JohnH1 is offline   Reply With Quote
Old 01-13-2009, 10:17 AM   #7
Okay, I flush the water cut off once a week, but how does one clean the water cut off? I also test the pressure relief valve as well.
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 05:26 PM
