How Can I Prevent Fuel Oil From Freezing - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2014, 09:32 PM   #1
How can I prevent fuel oil from freezing
Hello All,
I live in Long Island, NY for the past 7 years and this Janurary is the first time i have had issues with my fuel oil freezing. My tank is located above ground and It has happened twice so far, and I would like to prevent this from happening again.
I was told that I need to add anti-freezing chemical to the tank, but a specific product was not given.
So my question for all is do you know of any proven products to prevent fuel oil from freezing up?
TIA
newbieowner is offline   Reply With Quote
Old 01-23-2014, 09:54 PM   #2
Rewards Points: 1,192
Oil man should have it.
bobelectric is offline   Reply With Quote
Old 01-24-2014, 05:05 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,.... Yer Oilman will have it available, or order up #1 fuel oil to top off yer tank,...
#1 fuel oil is slightly thinner, with less wax, than #2 fuel oil,...
Standard operatin' procedure up here in the frozen north is to switch to #1 oil durin' the winter, in Any, 'n All outdoor fuel tanks,...
Btw,.... Have the filter changed at the same time, as ya might have a water in the fuel problem too,...
Old 01-24-2014, 09:26 AM   #4
biggles's Avatar
if the line is exposed into the house armaflex it and box it in on the run going in....that will keep the wind chill off it... at least
Old 01-24-2014, 10:29 AM   #5
Rewards Points: 948
I don't have oil, but I am told they mix kerosene in around here.
Toller is offline   Reply With Quote
Old 01-24-2014, 11:12 PM   #6
Thanks for all the replies
I buy oil COD, so I spoke with the company I purchase from. The customer service rep told me they only use #2 oil. this region rarely ever gets as cold as it is for a lengthy period of time.
Since this company is basically a middleman negotiating prices from various oil companies, they don't have any additives on hand.
anyone here used this product? http://www.thedieselstore.com/templa...=#.UuM5CHn0DPY
I am really wanting to switch to gas.........
villager missing on cylinder 5 Bigplanz Automotive Repairs 22 08-04-2013 08:32 PM
p-trap on in exterior wall install to prevent freezing Smahoney6 Plumbing 3 03-01-2013 10:07 AM
B-12 Chemtool versus SeaFoam DrHicks Automotive Repairs 16 10-01-2012 09:57 PM
Prevent Freezing Pipes alwayslearning Plumbing 3 03-05-2012 09:59 PM
Prevent Freezing Pipes alwayslearning Plumbing 0 02-26-2012 07:07 AM
