Old 12-17-2007, 09:20 PM   #1
drh
How can I increase PSI in my boiler? (pics attached)
Hello,
After reading "stonegirl"'s thread on not getting enough heat to her second floor rads, I believe I'm suffering from a similar situation - not enough pressure in my boiler system (my boiler, a Teledyne Laars Modutherm, installed in 1981) is currently sitting at 10psi, and my second story rads do not fill (they bleed air, but no water comes out).
Someone suggested to increase pressure, that a "boiler fill valve" must be opened, but the trouble is, I have no idea which valve I need to turn. So I've provided some pictures in the hopes someone can help me identify the proper valve.
I've attached four pictures - there are settings for High Limit (which as I understand, is water temperature) and another for "Circulator", which I'm not quite sure what its purpose is.
I'm guessing the "fill valve" is the nozzle next to the temperature/pressure gauge in boiler2.jpg, but I could be wrong.
Can someone help shed some light here?
Much appreciated,
Dan
ps - I'm a little concerned over the age of this boiler, and I'm looking into potentially replacing it come spring. How long would a boiler of this nature typically live?
How can I increase PSI in my boiler? (pics attached)-boiler1.jpg   How can I increase PSI in my boiler? (pics attached)-boiler2.jpg   How can I increase PSI in my boiler? (pics attached)-boiler3.jpg   How can I increase PSI in my boiler? (pics attached)-boiler4.jpg
drh is offline   Reply With Quote
Old 12-18-2007, 06:25 AM   #2
Need a photo of where the 1/2 copper water lines comes into the boiler.
redline is offline   Reply With Quote
Old 12-18-2007, 09:41 AM   #3
drh
I believe I may have solved this! Where the cold water comes into the boiler unit, I noticed a "backflow preventer" unit which has a small lever on the top of the unit which, when flipped, sounded as though it began allowing *more* water to flow into the unit. Almost immediately (within 10 mins, I noticed the PSI levels begin to increase).
As you can see by the gauge picture below, my new PSI is now in the 25 range -- and after bleeding the rads upstairs, are running incredibly warm, resulting in a very happy owner, and even happier girlfriend.
My question is now, running at 25PSI, am I risking damage to the unit? Or is 25 perfectly normal for a two story dwelling?
Thanks again,
.drh
How can I increase PSI in my boiler? (pics attached)-backflow.jpg   How can I increase PSI in my boiler? (pics attached)-gauge.jpg
Old 12-18-2007, 06:26 PM   #4
Union HVAC Tech.
The picture on the left shows the bronze colored pressure reducing valve, not a backflow preventer. I don't like that type of PRV and would change it to a B&G FB38 if it was me, it's much more reliable and has a easily cleanable strainer on the bottom.
25 psi is too high and may cause the relief vavle to blow off when it has run for a while. Drop the pressure back to 12 psi cold or 18-20 hot (@160F).
bigMikeB is offline   Reply With Quote
Beefing up these columns (pics attached) joeyboy Building & Construction 9 06-25-2007 09:46 PM
I need to enclose my Loft. Looking for your opinion what I should do. Pics attached TheLoft Carpentry 3 04-23-2007 02:44 PM
Water lines on sloped ceiling (pics attached) Mr. Michael Roofing 8 03-27-2007 03:13 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Need help please asap...patching plaster pics attached mood Building & Construction 2 07-30-2005 11:06 PM
