How Can I Check A Capacitor With A Meter - HVAC - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 07:19 AM   #1
How can i check a capacitor with a meter
The other day I replaced a condenser fan motor and all that was wrong with the unit was the capacitor. How can I check the cap with my meter to check if it's good or not.
Dennis Diaz is offline   Reply With Quote
Old 07-29-2010, 08:46 AM   #2
Rewards Points: 338
if your meter measures capacitance, that would be the easiest way. if not, discharge the capacitor and measure the resistance across it. the resistance should start out at 0 and go to infinity (usually 1 on the scale).
NitroNate is offline   Reply With Quote
Old 07-29-2010, 10:23 AM   #3
Method 1 uses a 1.1 megohm resistor from Radio Shack and a 9 v battery. And a clock!
Method 2, you need a doorbell transformer.
Method 3 uses a 4 W 120v incand. bulb and most nearly duplicates real world conditions.
What is the marked capacitance value in uF? What meter do you have?
Method 4 uses a cheapie analog ohmmeter and a clock.
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
SE Conduit & Meter placement acerunner Electrical 11 03-18-2010 08:46 AM
New clamp meter question Chevyman30571 Electrical 18 02-21-2010 11:35 PM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
Question on Code w/regards to holes in Meter Bases or Panels etc. tsenator Electrical 10 10-22-2009 10:37 AM
