-   -   How can i check a capacitor with a meter (http://www.diychatroom.com/f17/how-can-i-check-capacitor-meter-77415/)
Dennis Diaz 07-29-2010 07:19 AM
The other day I replaced a condenser fan motor and all that was wrong with the unit was the capacitor. How can I check the cap with my meter to check if it's good or not.
NitroNate 07-29-2010 08:46 AM
if your meter measures capacitance, that would be the easiest way. if not, discharge the capacitor and measure the resistance across it. the resistance should start out at 0 and go to infinity (usually 1 on the scale).
Yoyizit 07-29-2010 10:23 AM
Method 1 uses a 1.1 megohm resistor from Radio Shack and a 9 v battery. And a clock!
Method 2, you need a doorbell transformer.
Method 3 uses a 4 W 120v incand. bulb and most nearly duplicates real world conditions.
What is the marked capacitance value in uF? What meter do you have?
Method 4 uses a cheapie analog ohmmeter and a clock.
