How To Adjust Blower Speed? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-23-2009, 05:29 PM   #1
How to adjust blower speed?
Hi I have a Goodman pgb024075-1 and need to increase the speed of the blower. I have tried to understand the wiring diagram and couldnt find where to adjust it. Is it on the actual blower or on the electrical panel? Any help is greatly appreciated. here is a link to the diagram its on page 12. http://site.famousparts.com/goodman/IO-148.pdf
chrism7 is offline   Reply With Quote
Old 08-23-2009, 05:55 PM   #2
newtech's Avatar
Rewards Points: 164
Looks like you have a 2 speed motor. Black is for cooling and red is for heating. Check the board and see if that is how it is wired. Why do you need more fan speed??? What is the age of the unit???
newtech is offline   Reply With Quote
Old 08-23-2009, 06:12 PM   #3
The bedrooms get good flow but the living room kitchen and dining room all get poor flow. It has been recently serivced and all filters have been changed. Ive been under the house and couldnt find any loose ducts. So can I change the fan to a higher setting by moving the black wire or is there just one speed for hot and cold?
Old 08-23-2009, 06:17 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Newtech is right there is only two blower speeds for this design according to the schematics.
I agree why do you need more air?
You could have a capacitor going out or a fan motor starting to sieze up if you have noticed a reduction in air volume.
Have you check your filter lately?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-23-2009, 06:18 PM   #5
Rewards Points: 560
Black is high speed for this motor.
What type of dwelling do you have?
House, trailer, modulare?
Old 08-23-2009, 06:34 PM   #6
Its a house just moved in a month ago. The air is cold theres just not enough volume to cool some of the rooms. It has trouble keeping the room with the thermostat at 78 and will run for an hour or so at a time during the afternoon.
Old 08-23-2009, 06:37 PM   #7
Rewards Points: 560
What you may have to do is with the romms that have great air volume is install a damper in the branch and adjust them down a little making the air go to the other rooms.
Old 08-23-2009, 06:44 PM   #8
I have already closed the dampers a little in the bedrooms to try an increase the flow. It made a little difference but not enough and if I close them any more the bedrooms wont have enough volume.
Old 08-23-2009, 06:51 PM   #9
Rewards Points: 560
Where do you live?
and
What is the sq ft of your house?
Old 08-23-2009, 06:53 PM   #10
Columbia, sc and the sq ft is 1100
Old 08-23-2009, 07:01 PM   #11
Rewards Points: 560
Here in Ks 1100 sqft would need a 2.5tn a/c were from the model number you posted you have a 2 tn a/c and a 75k BTU furnace (Package unit) Not to say you are sized wrong but something to check.
Now that I have said this, this is only a rule of thumb.
Many factors come into play such as; ceiling height, attic insulation, number of windows, wall construction and insulation, region and more...
You might have a local company out to do a Manual J. There is a link on this site somewhere but Im not sure where. Or Google "Home owner Manual J" and do one yourself.
Whitout this it is really hard to say. Also with a package unit "I would think" this was installed after the house was built and ducting may not be sized correctly...just a thought
Old 08-23-2009, 07:29 PM   #12
Thanks for all the help ill look into a manual j
Old 08-24-2009, 12:28 AM   #13
your problem is most likely going to be poor duct design especially if the affected rooms are the furthest away from the unit
kennzz05 is offline   Reply With Quote
Old 08-24-2009, 12:14 PM   #14
Yeah the rooms farthest from the unit have the worst flow. Its like a maze of duct work under the house.
Is there a way to have heat, cool and fan all on same blower speed? pirateo HVAC 4 08-14-2009 04:13 PM
Adjust blower speed? Model and pic inside. ls3c6 HVAC 10 07-07-2009 12:27 AM
Amana furnace-variable speed blower yamfz1 HVAC 2 01-14-2009 05:26 PM
Low speed blower won't work in auto mode Eric F HVAC 16 10-29-2008 05:24 PM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 10:01 PM
