House Pre-Purchase Inspection Heat Strip Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 09:04 PM   #1
Hello,
My first post here!
I am buying a house in S. FL. Today, we did a HomeInsoection.
The house has a 2006 CarrierFC4ONF060 Air Handler Unit. The AC tested fine, but the resistive heat is not working despite the owner saying it worked this Winter.
Is there a Fuse or something to check? What would one expect this to cost to fix it? Best Case/Worst Case?
I'm fine with DIY and electronics, can I get the parts and fix this myslef?
Thanx!
Les
les_garten is offline   Reply With Quote
Old 03-19-2011, 09:45 PM   #2
HVAC / Plumbing
Could be a bad sequincer, heat coil, etc,. Need to check with V.M. to know for sure
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
les_garten (03-19-2011)
Old 03-19-2011, 09:52 PM   #3
Where would I go about finding some troubleshooting test points on these?
Any idea of a best case worst case cost? Trying to determine what my potential liabilities are on the house.
Thanx for the help!
Old 03-19-2011, 10:05 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
Since it was red-flagged during an authorized inspection, the present condition seen by the inspector over-rides what the seller said was fine earlier.
The seller and you should adjust the price to reflect the materials and labor to correct the inadequacy of the system, if possible.
Dick
concretemasonry is offline   Reply With Quote
Old 03-19-2011, 10:33 PM   #5
Dick
Dick
I understand that. I'm just rying to get a worse case best case estimate.
It is a short sale, but that is really irrelavent to my question.
I just am looking for the potential cost one extreme to the other.
Old 03-19-2011, 10:42 PM   #6
Now I understand the situation better.
Dick
Old 03-19-2011, 10:54 PM   #7
Dick
Any idears about potential cost?
Doesn't seem like it would be that much.
heat pump wiring problem - new thermostat tygrr94 HVAC 8 01-17-2011 08:18 PM
York Heat Pump Wiring Problem floridafrank HVAC 0 01-08-2011 05:51 AM
Bryant/Honeywell T841A 1639 thermostat problem MikeInMobileAL HVAC 0 01-08-2010 07:14 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
