House Not Heating Evenly - HVAC - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 07:46 PM   #1
House not heating evenly
I have a single story house and notice that the rooms closet to the hvac system heat/cool faster and get more air flow. Is there something i should check and do in order to have a balanced air flow throughout the house?
breeze76 is offline   Reply With Quote
Old 01-18-2013, 07:54 PM   #2
how
Rewards Points: 1,104
Most outlets can be adjusted to balance the heat/cooling output. In your case it would involve dampening down the outlets closest to your furnace.
This should always be followed by a furnace temp rise test to make sure your adjustments are not causing the furnace to run too hot.
how is offline   Reply With Quote
Old 01-18-2013, 08:00 PM   #3
I tried that but does not seemed to work well... I was wondering about putting adjustable dampers on the plenum so there would be less back pressure and wasted air-flow. I was thinking of using some type of air flow meter to set the dampers. Your thoughts?
Old 01-18-2013, 09:15 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
Do you have adequate return air vents in the far end of the house? If they are adequately sized the system will work better when you throttle down the supply registers close to the furnace since cooler air will be drawn in when the fan is operating.
Dick
concretemasonry is offline   Reply With Quote
Old 01-19-2013, 07:29 PM   #5
Dick
The only return vents are located on the bottom of the furnace in the part of the house that the air flows better.. No return on other end of the house where the air does not flow good. To put return air in the other part of the house can not possibly be done due to the fact that the furnace has the return at the bottom of it locate in the wall...
Brainstorming a passive/active solar heating project, want opinions, please! YerDugliness Green Home Improvement 4 07-13-2013 06:29 PM
New heating system in old house - needs lots of help beengone HVAC 31 09-19-2012 12:00 PM
Heating a 700 sq. ft. house. tatieanne HVAC 5 08-25-2010 03:21 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Heating Unit in the Attic Bad Idea? Part of House on Slab cloves HVAC 3 08-18-2009 11:37 AM
