House A/c Coils - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:55 PM   #1
House a/c coils
How and what I would use to clean my house a/c coils on a up and down unit that is in a closet
Gardec is offline   Reply With Quote
Old 06-13-2012, 09:59 PM   #2
Rewards Points: 216
i used a vacuum cleaner with a brush on the end of the hose. and my A coil was about 90% clogged.
Fix'n it is offline   Reply With Quote
Old 06-14-2012, 08:48 AM   #3
Rewards Points: 282
vacuum cleaner may not work completely as the condensate tends to make a nice dried on layer.
coil cleaner does a remarkably good job, followed by a quick hose off (garden sprayer full of water) and vacuum.
jcrack_corn is offline   Reply With Quote
Old 06-14-2012, 09:16 AM   #4
MarginallyQualified
Rewards Points: 2,464
Cleaning the coil is the easy part.
GETTING to the coil... well, that can be tricky.
Old 06-14-2012, 11:38 AM   #5
Household Handyman
Rewards Points: 1,408
WHOA ! ! This video leaves out the most important part before he even lights the torch: Evacuating the freon. NOT something a homeowner can, or should even be trying to do.
Old 06-14-2012, 04:52 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Yeah..... You don't want to be getting a flame anywhere near refrigerant..... unless you have good life insurance....... and don't mind a painful agonizing death.
Old 06-14-2012, 07:05 PM   #7
Rewards Points: 1,062
Not sure why this thread isnt in the ac forum, but no need to remove the couil from the air handler. yes, its tougher to clean, but man, no need to evacuate/solder/weld, etc/ Put on safety glasses, f;lashlight, pump sprayer, get underneat it!!! Thats it! Oh, once you soften up the crud, as it IS encrusted on hard, start brushing the crud ooze/hair mat off with a stiff, but very narrow grout cleaning brush. Start up high (at the "V"), then work down.
Works for me every time!! Ive done many of them!
good luck.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-14-2012, 09:33 PM   #8
Rewards Points: 216
well. i guess i got lucky. my crud was not baked on. perhaps because it is only 5 years old. i think much/most of it was dog hair, from the PO's
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
