Old 10-05-2011, 02:58 PM   #1
House in Boo
I have a coleman furnace model # DGAT090. The diagnostic lite is flashing 5 times / gas valve engergized with no call for heat. Any answer for a fix to this concern?
bogie is offline   Reply With Quote
Old 10-05-2011, 03:43 PM   #2
I'm Your Huckleberry
House in Boo
New control board.
Doc Holliday is offline   Reply With Quote
Old 10-05-2011, 08:19 PM   #3
House in Boo
Grounded flame sensor or its wire will do that too.
Old 10-06-2011, 03:25 PM   #4
House in Boo
Where might I look for the flame sensor / wiring?
Old 10-06-2011, 03:28 PM   #5
House in Boo
Originally Posted by Doc Holliday View Post
New control board.
Is there a way to verify if its the control board. Quite a pricey part to try to see if it fixes the problem.
Old 10-06-2011, 06:31 PM   #6
House in Boo
Should be 3 wires going into the burner. Disconnect the wires and check for continuity to the burner. If there is then you get to the fun part of removing the burner from the heat exchanger without breaking the fragile as an egg ignitor.
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 03:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
