Old 07-07-2012, 11:22 AM   #1
biggles's Avatar
in the hot weather...refrigerators
maint item if you have the type with the fan and condenser coil on the bottom behind the kick panel good time to get in there and brush the dust off.from the back remove the cardboard cover clean out the condensate pan and wipe down the blades of the motor....it will work easier to maintain the frig/freezer.it is a heat source moving air and collects cat,hair dust bigtime...
Old 07-13-2012, 10:24 AM   #2
Special User
Agreed. I like to vacuum mine and then hit it with some compressed air (like computer duster). We don't even have a cat and it still cakes with dust...
tylernt is online now   Reply With Quote
Old 07-13-2012, 12:35 PM   #3
which of course brings to mind the entire design of most Fridges.... why is the heat producing equipment below the cold.... doesnt heat rise... why not the compressor etc on top (like sub zero brand).... and of course there is less dust up in the air, compared to on the floor... does not make sense to me!!!!
bobinphx is offline   Reply With Quote
Old 07-13-2012, 01:09 PM   #4
biggles's Avatar
looks & style kick in bigtime... all low and out of sight for max cubic' ft or is it inches???
Old 07-13-2012, 02:01 PM   #5
Cubic inches make it sound bigger, kinda like rating torque in in-lbs vs ft-lbs
wheelsup is offline   Reply With Quote
Old 07-13-2012, 02:42 PM   #6
They should be tied to your VRF system anyway so all that waste heat is not ejected into the living space.
ionized is offline   Reply With Quote
Old 07-14-2012, 01:48 AM   #7
You ever try and reach stuff stored on top of a sub zero fridge?
Evstarr is offline   Reply With Quote
Old 07-14-2012, 03:53 AM   #8
mareemunn2040 is offline   Reply With Quote
replacing weather stripping on front door cao911 Remodeling 5 09-07-2012 05:29 PM
Refinishing door new weather stripping recommendations bryanp22 Windows and Doors 2 05-01-2012 11:12 AM
Door Problems in Cold Weather coldnyc347 Building & Construction 5 02-04-2011 05:24 PM
Oakland/East Bay weather vs. Seattle brooklynsual Off Topic 2 12-06-2008 11:01 PM
Oakland/East Bay weather vs. Seattle jek.don Off Topic 1 11-11-2008 01:58 PM
