Old 11-14-2012, 09:10 AM   #1
Hot water vs cold to humidifier
Has anyone done any research as to whether there is any difference in humidification by using the cold water line vs hot water to feed a bypass humidifier?
I am replacing an old humidifier and would like to use the existing line from the cold water pipe to hook up to the new humidifier. Thanks.
billyg is offline   Reply With Quote
Old 11-14-2012, 10:36 AM   #2
If the unit is mounted on the return side, hot water makes more sense.
veesubotee is offline   Reply With Quote
Old 11-14-2012, 11:02 AM   #3
raylo32's Avatar
It should provide a higher level of evaporation but I can't tell you what % improvement it would be. Hopefully someone else here can. But this type of humidifier typically flows about 8 gallons per hour when activated (which for me in the coldest/dryest part of winter is whenever the furnace runs) so it would bump up your water heating costs significantly.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-14-2012, 11:28 AM   #4
I saw this asked somewhere,before and the answer was it could possibly encourage Legionairres Disease.
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
Canucker (11-14-2012)
Old 11-14-2012, 01:50 PM   #5
One of the things I heard on this was using the hot water was better because as you heat the water up it tends to drop out base minerals into the Hot water tank, so you end up with less scale and sediment in your humidifier.
HVACDave is offline   Reply With Quote
Old 11-14-2012, 07:00 PM   #6
Roofmaster
Interesting concept, but I would think that if the rate of use would be so low it would not matter, because the water would cool before it hit the unit but it might keep the line from sweating if you use a copper water line. I have never had good results with those in furnace units. They cake up with efflorescence in no time and only work when the blower is on. I use a cabinet unit and man does it put out the humidity. About 6 gallons in a day.
jagans is online now   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
Warm water coming from cold faucets ygillard Plumbing 2 03-02-2012 03:24 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Leaking Water Heater (from Cold Inlet?) doesntmatter Plumbing 7 07-12-2010 10:30 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
