Old 12-25-2009, 11:38 PM   #31
Hot water starts hot but gets cold quickly.
I have an off the wall question. Does your boiler have a minimum flow device in the coil that causes the boiler to only come on above a certain cubic feet per minute of water flow, like a tankless water heater does? Maybe you have a low flow shower head that has a flow restrictor that keeps the flow at 2 gallons per minute which is below the minimum flow rate of tankless water heaters. Try removing the shower head and see how long you have hot water.
log_doc_rob is offline   Reply With Quote
Old 12-26-2009, 06:06 AM   #32
i didn't read far enough to know if someone suggested flushing the water heater out? it is not hard. you can even do it w/o turning pilot light off if you've help.
i think this is considered yearly maintenance.
hope you fixed it!
rosco is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
cold water runs hot phxhouser Plumbing 4 06-11-2008 10:03 PM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 07:20 PM
