Old 02-09-2008, 10:05 AM   #1
Hot water radiator parts? Bleed Valves
I was just going through the process of bleeding my hot water radiators, when i noticed one of the bleed valves is damaged, and inoperable.
I *BELIEVE* I have the standard 1/8" bleed valves.
Does anyone know where to get these online, and what I need to do to install them?
I was planning on turning off the furnace
turning off the water supply to the furnace
then doing the swap, should this work?
Let me know what you guys think.
DanBress is offline   Reply With Quote
Old 02-09-2008, 12:30 PM   #2
Steam or hot water system?
Can you post a photo of the current bleeder?
redline is offline   Reply With Quote
Old 02-09-2008, 12:40 PM   #3
I am pretty sure this is what I have/want.
Old 02-09-2008, 09:08 PM   #4
biggles's Avatar
for what thet cost and the problems they might cause when they leak,you might want to go around the house and do all of them...shut the boiler down pump if you have it and bleed off the riser pressure off the highest one if possible.some teflon tape on the new ones going in won't hurt
Old 02-09-2008, 09:09 PM   #5
Good idea biggles. but do you know where to buy them?
Old 11-16-2008, 04:32 PM   #6
I too would like to know where to purchase new air bleeders for my hot water system.
sparky672 is offline   Reply With Quote
Old 11-16-2008, 07:54 PM   #7
any heating /plumbing supply should have them. in a pinch you can bleed by backing the whole bleeder out and wiggleing it to purge the air
kennzz05 is offline   Reply With Quote
Old 11-16-2008, 08:02 PM   #8
Exactly how I'm doing it now.
Don't they also make an auto-bleeder for these? Maybe more expensive than it's worth?
Old 11-16-2008, 08:12 PM   #9
i kno steam have autos but not sure bout hot water
Old 11-16-2008, 08:23 PM   #10
ok, thanks.
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
