-   -   Hot water radiator parts? Bleed Valves (http://www.diychatroom.com/f17/hot-water-radiator-parts-bleed-valves-16805/)
DanBress 02-09-2008 09:05 AM
I was just going through the process of bleeding my hot water radiators, when i noticed one of the bleed valves is damaged, and inoperable.
I *BELIEVE* I have the standard 1/8" bleed valves.
Does anyone know where to get these online, and what I need to do to install them?
I was planning on turning off the furnace
turning off the water supply to the furnace
then doing the swap, should this work?
Let me know what you guys think.
redline 02-09-2008 11:30 AM
Steam or hot water system?
Can you post a photo of the current bleeder?
DanBress 02-09-2008 11:40 AM
I am pretty sure this is what I have/want.
http://i11.ebayimg.com/08/i/000/d7/be/e3c5_1.JPG
biggles 02-09-2008 08:08 PM
for what thet cost and the problems they might cause when they leak,you might want to go around the house and do all of them...shut the boiler down pump if you have it and bleed off the riser pressure off the highest one if possible.some teflon tape on the new ones going in won't hurt
DanBress 02-09-2008 08:09 PM
Good idea biggles. but do you know where to buy them?
sparky672 11-16-2008 03:32 PM
I too would like to know where to purchase new air bleeders for my hot water system.
kennzz05 11-16-2008 06:54 PM
any heating /plumbing supply should have them. in a pinch you can bleed by backing the whole bleeder out and wiggleing it to purge the air
sparky672 11-16-2008 07:02 PM
Exactly how I'm doing it now.
Don't they also make an auto-bleeder for these? Maybe more expensive than it's worth?
kennzz05 11-16-2008 07:12 PM
i kno steam have autos but not sure bout hot water
sparky672 11-16-2008 07:23 PM
ok, thanks.
