Old 05-03-2009, 01:31 PM   #1
Default Hot Water Problem
Hi,
New to the forum.
Couple of questions...........on my Weil-McLain Gold Oil Burner
1) I have noticed that my shower water requires a bigger turn of the faucet to get hot water. ......... what is the control on the boiler to turn the water temp up? and.......... why would it change like that? (boiler was serviced in December).
2) My boiler has been discharging (through outlet drain pipe) quite a bit of water ......... maybe about 1 gallon every couple of months........ is this normal? ..... if not, then what would cause that?
3) A couple of years back, my heat registers were making noise.... believe was told by our oil company (who also yearly service our system), that would cost about $300 to remove air from the pipes? Is this something that need professional to do? Also.. have read that coils may need to be cleaned????
Thanks for the help.
Bob
bob6831 is offline   Reply With Quote
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Hi, I'm Terri Turco with Expert Village and now we're really going to get going and melt that chocolate. Now as you see behind me I've got the oven. I've got my little pot with my glass bowl and chocolate inside. Now remember, the pot needs to be 3/4... Read More »
Hi. I'm Jennifer Cail and on behalf of Expert Village, I'm going to show you how to make this rich espresso fudge. For the equipment that you will be using to make your fudge, there are several important pieces that are key for the success. You're going... Read More »
I'm Cathi Pare, with water resources in Santa Barbara speaking to you today with expertvillage.com and we are actually looking at drip systems right now and maintenance you can do as a home owner. One of the first things you are going to do before your... Read More »
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 11:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 01:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
recirculating hot water problem cliff Plumbing 3 08-20-2007 01:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
