Old 11-14-2011, 04:36 PM   #1
hot water heating radiators
can I include steel radiator in the loop with my old-time cast iron radiators or should I put in a new heating loop?
CATSchuck is offline   Reply With Quote
Old 11-14-2011, 06:18 PM   #2
An old Tradesmen
New loop and own thermostat work best. The steel ones won't hold the heat the same as the cast iron ones.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Hot Water Heating Problem....please help gor4200 HVAC 6 01-24-2011 02:17 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
