Hot Water Heating, Burst/frozen Pipes, Use Pex Etc??? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 03:55 AM   #1
Hot Water Heating, burst/frozen pipes, use pex etc???
Good Morning, looking for someone in who does boiler/hot water heating repairs... I recently bought a property which went thru the winter without properly winterizing the hot water heating system and I have found a few burst fittings in the wall/ceiling... It looks like black iron was used... 3/4" main with 1/2" branch lines... I am wondering if there is a substitute such as the newer pex tubing that may be used in this system... The house is about 60 years old and has a tube and fin radiator (not baseboard)... Any way it would make the repair a lot easier if a flexible piping/tubing could be used and would also have fewer joints... Any suggestions??? Thank you, John
diyjohn is offline   Reply With Quote
Old 11-14-2008, 05:07 AM   #2
An old Tradesmen
Rewards Points: 7,400
Hpex can be used.
Old 11-14-2008, 02:22 PM   #3
Thank you beenthere... i will look into the hpex... what type of fittings can be used to connect the hpex to the iron, is it brass, stainless or????? I have already made some repairs using iron pipe but it was a bear, there have been some tight spaces and i am thinking that if i find another burst fitting that i would like to try something more flexible... Obviously this system was originally installed before all of the walls etc were finished... Also I would assume this system gets up to 180+ degrees, maybe 200???... Later, John
Old 11-14-2008, 04:07 PM   #4
An old Tradesmen
Only Hpex fittings. They're brass.
They are special fittings. You'll have to get them from the same supplier that you get your Hpex from.
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
blockage in hot water heating pipes? gary in co HVAC 1 01-18-2008 03:36 PM
PVC Pipes Pop And Click When Water Runs jasonsullivan Plumbing 3 01-16-2008 02:41 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
