Hot Water Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 11:22 PM   #1
hot water heating
how to wire up the honeywell relay #r8239d 1007 which I have 2 zone ,each has a 2 wire thermostat for (zone valve with 2yellow and 2red wire ) and taco pump for hot water heating could some give a simple wire diagram
fasteddie438 is offline   Reply With Quote
Old 11-26-2010, 11:58 PM   #2
Rewards Points: 150
I've worked with a lot of those. They're very well labeled. The diagram is right inside of the cover.
emolatur is offline   Reply With Quote
Old 11-27-2010, 08:01 AM   #3
Rewards Points: 1,214
Repost under HVAC there are some wizards over there that work on this stuff every day. They will set you up.
COLDIRON is offline   Reply With Quote
Old 11-27-2010, 08:02 PM   #4
An old Tradesmen
Rewards Points: 6,072
Don't post double threads in the forums. Please ask to have it moved to the appropriate forum.
You can do this by clicking on the report button. And telling us you posted in the wrong forum, and would like it moved to the correct one.
Old 11-28-2010, 08:47 AM   #5
the Musigician
DangerMouse's Avatar
Why would you need to heat hot water?
DM
Old 11-28-2010, 08:59 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
You don't if you are in Iceland. Comes out of the ground hot not icy.
Old 11-28-2010, 09:02 AM   #7
An old Tradesmen
DM
Cause hot water at 110F isn't as hot as hot water at 120F.
Old 11-28-2010, 09:20 AM   #8
Hvac Pro
yuri's Avatar
So, when you are going the wrong way on a one way street and someone yells at you "you are going the wrong way" how do they know where you are going?
Old 11-28-2010, 05:52 PM   #9
Have faith fast one of those guys will help you, I hope.
Old 11-28-2010, 07:03 PM   #10
newtech's Avatar
Rewards Points: 164
Isn't it nice to see the Mods take a post serious
I know this a DIY site. But geeze
newtech is offline   Reply With Quote
Old 11-29-2010, 08:14 AM   #11
Recheck your numbers and letters and include the( CONTROL NUMBER)
the relay is in and repost with a question worded with more information maybe someone out there will be able to help you. Just trying to steer you in the right direction. Apparently there is a conflict with your numbers or your question. Maybe even a picture will get you an answer.
Repost in the proper format.
Old 11-29-2010, 05:15 PM   #12
An old Tradesmen
And what don't you like about those post.
While a little humor is thrown in to responses at times. When the OP ask a more defined question about what they don't understand, or what they need help with. They will be given the help they need. Within the limits of forum based aid
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
uneven heating from hot water system JLAP Plumbing 9 12-21-2009 01:14 PM
Hot Water Heating, burst/frozen pipes, use pex etc??? diyjohn HVAC 3 11-14-2008 05:07 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
