| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Heat an Ice Fishing House
by eHow.com
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
How to Make a Fireplace More Efficient
by eHow.com
The efficiency of a fireplace depends on several factors. Though the design is certainly important, it isn't the only thing to consider. Adding components and performing routine maintenance are critical to maximizing efficiency. No matter what type of... Read More »
How to Clean Your Chimney
by eHow.com
There is nothing quite like a crackling fire in the fireplace on a cold winter day. As wonderful as this may sound, this lovely fire can turn deadly if your chimney is not properly maintained. Every chimney should be cleaned at least once a year to... Read More »
How to Insulate a Water Heater
by eHow.com
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
Painting Chimneys for a Watercolor Houses
by Expert Village
Now we're going to be doing chimneys. So we're going to do yellow and rose and a little bit of blue. And produce the dark part of the chimneys. Now we're going to lighten it up and do the light part of this chimney. And we have to go darker on this... Read More »
