Hot Water Heater Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 06:33 PM   #1
hot water heater venting
Is 4" the new code for water heater natural draft size? Also, is it ok to use foil tape on the vent pipe for a water heater?
markharmon is offline   Reply With Quote
Old 05-23-2013, 07:55 PM   #2
Rewards Points: 616
4 inch not manditory here yet...... foil tape is fine to use....
carmon is offline   Reply With Quote
Old 05-23-2013, 09:46 PM   #3
roofingquotes's Avatar
Depending on the plumbing code on the state you are.
roofingquotes is offline   Reply With Quote
Old 05-24-2013, 11:17 AM   #4
how
Rewards Points: 1,104
And sometimes it falls into the municipal jurisdiction of the area providing the permit (like Vancouver BC).
4 inch is asked for here and foil tape is fine.
how is offline   Reply With Quote
Old 05-24-2013, 02:19 PM   #5
Rewards Points: 1,216
Make sure the pipe is installed in the direction of flow crimped end inside the non crimped end to wards the chimney. I like to install drill screws 2 in each joint.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 05-24-2013, 02:51 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
Typically it's dictated by the size of the flue on the heater. There would never by a reduction in size allowed.
Your going to have a choice of two types of pipe. Single wall or B-Vent (double walled). With single wall you have to stay 6" from any combustionable material. B-vent, 1".
On single wall, you are typically required to have 3 screws per joint. B-vent....they interlock so most inspectors don't require screws.
Both types require tape...metal tape....do NOT use duct tape. And you should also tape the seams on elbows...
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 08:48 PM
Furnace and Water Heater Venting SallySensation HVAC 5 03-05-2013 05:53 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Hot Water Heater Venting...need suggestions flyhop Plumbing 11 01-27-2010 12:50 AM
