Hot Water Heater Leaking From Bottom Valve & Not Heating Up!?!! HELP - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 10:50 AM   #1
Hot Water Heater leaking from bottom valve & not heating up!?!! HELP
Hello,
My hot water heater this morning would not heat up a shower for me. So i went down to the garage to have a look and there was a small puddle developing under/around the heater. I was able to pinpoint the leaking to the drain valve on front at the base of the heater. But would this prevent my water from heating? is this an easy fix? please help
-Aaron-
auretsky is offline   Reply With Quote
Old 03-20-2011, 11:00 AM   #2
DIY staff
Rewards Points: 7,174
Please do not keep posting the same question--once is enough.--Moderator---
Old 03-20-2011, 11:02 AM   #3
yeah i didnt mean to the page kept timing out when i was submitting most of posted it the times it timed out. sorry
Old 03-20-2011, 11:08 AM   #4
DIY staff
The heater---Is it gas or electric? How old?
The chances are the tank is leaking---it's likely the water is coming out around the valve opening---
The water may have extinguished the pilot light.
If it's leaking from the tank --the unit is dead.----If the drain valve is the cause,you might get lucky and be able to unscrew the valve and replace it.-----Mike----
Old 03-20-2011, 11:11 AM   #5
Thanks mike,
It is gas and i want to say maybe 2 or 3 years old...could be wrong though. Yeah it is a very slow leak like a drip per 30 seconds coming from that valve and nothing else so ill check out that and the piolit thanks for the advice ill let you know if it works.
Old 03-20-2011, 11:18 AM   #6
DIY staff
Might be a coincidence----the unit is still rather new---The valve---if the drip won't stop,go to the garden section of the store and get a hose cap. Just screw it over the valve---drip stopped.--Mike--
Tags
hot , leaking , leaking heater , not hot water
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 07:37 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
water heater ball valve leaking DIYGST Plumbing 6 01-19-2009 12:32 PM
