Hot Water Heater Flue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 05:16 PM   #1
Hot water Heater Flue
Hey Guys I currently have my hot water heater flue exiting out from my basement into my chimney. My problem is that my chimney is falling apart so I wasnted to tear it down. My question is can I have my hot water heater flue run about 5 feet straight across my basement and exit the side of my house? Or could I have the flue exit out side my house where my current furnace exits out the side of my house? Any imput on this would be great thank you so much in advance.
rchrivera is offline   Reply With Quote
Old 12-21-2009, 05:19 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
That's how it is at my parents' house. Most likely requires a blower if you don't have one already.
Old 12-21-2009, 05:26 PM   #3
Heres a picture of my current setup:
Old 12-21-2009, 06:32 PM   #4
single exhaust flue on furnace?
Old 12-21-2009, 07:58 PM   #5
An old Tradesmen
Rewards Points: 8,142
Moved thread to HVAC forum.
That water heater requires you get a power venter to sidewall vent it.
So it becomes a better option to get a direct vent water heater, then to get the power venter. Since many of them become very loud.
Old 12-21-2009, 08:46 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 380
How old is the current tank. If over 6-8 yrs old I would consider an electric tank even if you have to put in a electrical subpanel. Direct vent water heaters are EXPENSIVE and don't last longer than regular ones. Power venting that one would be very expensive and complicated.
Old 12-21-2009, 08:56 PM   #7
Pictures say a thousand words..1st to go with a new power vented tank equipped with a vapour sensor,you risk having no hot water due to sensor shutting tank down due to conditions of bsmt,ie:moisture,sewer gas, whatever,that looks like a REAL bsmt.2nd direct vent ,unless the vent termination was relocated ,which it could be ,i would'nt want to punch a hole thru chim to accommodate venting. mm..ya..
hf05 is offline   Reply With Quote
Old 12-21-2009, 09:01 PM   #8
Call the local city/county inspector and find out if it's even legal in your area. They will tell you how to do it and comply with local codes.
Old 12-21-2009, 09:12 PM   #9
removed. Call a couple of reputable ,licensed HVAC companies and get quotes.Basically u have 3 options.power vent.direct vent,or if thats a masonary chimney ,drop a 4 inch liner down and go with conventional..leave the political monkeys out of it,they probably don't have a clue anyway..just a thought..
If you can't express yourself without making personal attacks against others you will be banned
This is the 3rd time in one day
Last edited by Scuba_Dave; 12-22-2009 at 11:06 AM. Reason: removed personal attack
Old 12-22-2009, 10:26 AM   #10
Rewards Points: 392
Can you take a picture of your furnace venting and post it?
zootjeff is offline   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Water heater flue advice... skipjack Plumbing 2 08-18-2008 05:25 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
