Old 01-01-2007, 05:53 PM   #1
hot water heater
I am trying to figure out how to adjust my water temperature on my hot water heater. I have a Super Ultra SSU 45 and cannot figure it out. Any help would be appreciated. The reason I ask is because I have never owned a house until now and I am brand new to this. I just figured that it seemed like something I would be able to adjust rather than call someone in for help.
bonk is offline   Reply With Quote
Old 01-01-2007, 06:05 PM   #2
Thoroughbred Mopar Man
hot water heater
Hi bonk
If you have the owners manual to the boiler, look in it for the operating control. Or it could possibly be written on it if you look at the boiler. Just remember on a hot water system, Do Not Go Over 190 deg or you could damage your system.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-01-2007, 06:13 PM   #3
hot water heater
The builder left me everything but the manual to this. Unfortunately I guess I will have to have someone come in. I am smart enough to know when I should not touch anything. Thanks for the reply!
Old 01-01-2007, 06:14 PM   #4
hot water heater
Is this a boiler or a water heater.
trollmastergeneral is offline   Reply With Quote
Old 01-01-2007, 06:27 PM   #5
hot water heater
It's a boiler. SuperStor Ultra SSU 45
Old 01-01-2007, 06:40 PM   #6
hot water heater
If it is a boiler you should set the aqua stat at 180 and the secondaire limit at 190. Just like rusty said .of course this is assuming you dont have any in floor heat.
Old 01-01-2007, 06:45 PM   #7
hot water heater
I do not have floor heat in floor heat. I assume that you mean gradiant heating? I am still unsure of where to raise the temps taht you are talking about.
Sorry, I do not understand all of this, I am brand new.
Old 01-01-2007, 07:01 PM   #8
hot water heater
Inside of boiler is a aqua stat.thats where you would set the tempature.why do you think it needs to be turned up
Old 01-01-2007, 07:11 PM   #9
hot water heater
The hot water takes a long time to reach the showers and faucets around th ehouse regardless of th eproximity to the boiler. The laundry does not seem to get a clean smell, it seems musty. I have been told that this could also be due to the lack of hot water to the washer machine.
Old 01-01-2007, 07:24 PM   #10
hot water heater
I take it you have a boiler with a boiler mate for your hot water
Old 01-01-2007, 07:33 PM   #11
hot water heater
I am not even sure what a boiler mate is
Old 01-01-2007, 07:39 PM   #12
hot water heater
can you post a picture of what you have? If you cant I would strongly sugest you have service person come to your house.
Old 01-01-2007, 07:41 PM   #13
hot water heater
I can't but thank you. I guess I will have someone come in. Thanks for your posts.
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 07:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
