Hot Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 06:42 AM   #1
hot water heater
Not sure if this is HVAC or plumbing question...but here goes-
I have a techtanium 55 indirect hot water heater with a burnham es5 boiler (gas). Both units are 18 months old. For the past few days I have been running out of hot water. It seems the only way to get the boiler to run is when I have heat running to the radiators. When I run the house thermostat a small quantity of water heats up (seems like the proper temp.), enough for a couple of showers, before water becomes tepid then cold. Any ideas what may be causing this? Both units were professiolnally installed, but was hoping maybe a diy fix.
sharp is offline   Reply With Quote
Old 04-02-2013, 09:59 AM   #2
how
Rewards Points: 1,104
I would start by examining if the zone valve that controls the boiler firing/pump run & water flow through your indirect heater is working properly. Most Zone valves have covers that slide off. Examine how the suspect zone valve works compared to any of the other zone valves when there is a thermostat call for heat.
Check if the ZV motor is opening up the valve enough to engage it's internal electrical proving switch. Usually the switch or the ZV motor is the fault. It sounds like your ZV motor might be frozen in a partially open position or the proving switch is not being activated so that only the house thermostats can supply the indirect heater with a hot water flow.
how is offline   Reply With Quote
Old 04-03-2013, 05:35 AM   #3
Thanks for the help. I toggled the spring inside the ZV a bit and the boiler kicked on. Appears to be firing ever since. Do you advise to change the ZV or should this continue to work?
Old 04-03-2013, 06:06 AM   #4
Rewards Points: 196
Depending on the brand, you can just replace the powerhead assy which has the motor and end switch in one part.Wont need to replace whole valve assy.
HVACTECH96 is offline   Reply With Quote
Old 04-03-2013, 07:35 AM   #5
thanks
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
