Hot Water Heat Pump? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 10:15 AM   #1
Is anyone familiar with the "AirTap" hot water heat pump by airgenerate? I'm looking to replace my current electric hot water tank with something more efficient. Was originally looking tankless but came across this heat pump which would also help remove the moisture in the basement (althoug i'm adding new gutters and regrading the lawn to ultimatly resolve the damp basement). Are these pumps reliable, produce enough hot water, and what kind of maintenance is required? Any recommendations or reviews from experience with the product would be great.
rdavis84 is offline   Reply With Quote
Old 03-06-2009, 03:57 PM   #2
An old Tradesmen
Rewards Points: 6,582
A. How warm is your basement now.
Its going to be a lot colder with that HP.
B. Is your basement ceiling insulated.
Your first floors floor will become very cold.
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
water source heat pump mountaineer HVAC 1 08-02-2007 06:47 PM
