Old 12-29-2012, 02:32 PM   #1
mlw
hot water heat
how do I relieve the pressure on my new yorker boiler
mlw is offline   Reply With Quote
Old 12-29-2012, 04:19 PM   #2
Master General ReEngineer
Bondo's Avatar
hot water heat
Ayuh,.... That's a loaded, involved question, with not near enough background info....
Oil fired,..??
Gas,..??
The make-up water pressure regulator could be bad,...
The pressure tank could be bad,...
What pressures are We talkin',..??
Ya got any pictures of the near boiler plumbin',..??
Old 12-29-2012, 05:20 PM   #3
hot water heat
Sometimes if you whisper softly to it but usually draining water from drain does the trick.
HVACTECH96 is offline   Reply With Quote
Old 12-29-2012, 08:13 PM   #4
how
hot water heat
The real question is what pressure do you have in it?
Does it vary from being hot to being cold?
How high above the boiler is the highest radiator in your home?
Does one half of your expansion tank sound empty when you tap it?
Is your pressure releif valve venting.
What temp is the water showing when operating.
how is offline   Reply With Quote
Old 12-30-2012, 03:30 AM   #5
An old Tradesmen
hot water heat
Usually by the boiler drain valve. but what is happening that you want to lower/relieve the pressure. There may be a cause that you need to address also.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
