-   -   hot water heat (http://www.diychatroom.com/f17/hot-water-heat-167699/)
mlw 12-29-2012 02:32 PM
hot water heat
how do I relieve the pressure on my new yorker boiler
Bondo 12-29-2012 04:19 PM
Ayuh,.... That's a loaded, involved question, with not near enough background info....
Oil fired,..??
Gas,..??
The make-up water pressure regulator could be bad,...
The pressure tank could be bad,...
What pressures are We talkin',..??
Ya got any pictures of the near boiler plumbin',..??
HVACTECH96 12-29-2012 05:20 PM
Sometimes if you whisper softly to it but usually draining water from drain does the trick.
how 12-29-2012 08:13 PM
The real question is what pressure do you have in it?
Does it vary from being hot to being cold?
How high above the boiler is the highest radiator in your home?
Does one half of your expansion tank sound empty when you tap it?
Is your pressure releif valve venting.
What temp is the water showing when operating.
beenthere 12-30-2012 03:30 AM
Usually by the boiler drain valve. but what is happening that you want to lower/relieve the pressure. There may be a cause that you need to address also.
