#1 |
Hot water coil troubles
Hi i am having trouble with a hydronic forced air hot water coil. It is mounted in the return air handler of my system. I have replaced it 2 times now cause of what looks to me to be electrolysis around the top 2 copper tubes where they meet the steel frame of the coil housing. So if this is the case is it a good idea to add a ground directly from the case of the coil to the ground bar in my electrical panel. or is this just a case of bad luck with 2 consecutive defective coils (seems to strange to be ) they last about 2-3 years before i see the leak start. I also froze one of the coils previously so i have changed this thing 3 times now in all. I am getting real good at replacing the coil but would like to not have to replace again. any advise or idea are greatly appreciated.
#2 |
Electrical Contractor
I'm no expert on this, hence the screen name, but could a dielectric fitting/union to connect the 2 dissimilar metals work for this?
#3 |
Hvac Pro
Do you have any unusual fumes in your house/basement. Ie: is the wife running a hair salon and using peroxides? Chemicals may eat your coil. Do you have a workshop/paint booth nearby?
#4 |
The coil is pre built and assembled through the steel frame so no fittings are involved here. its really just a radiator much like the one in a car just with no tanks on the sides. and no to the smells/fumes, although the house has been undergoing a remodel for some time now. So for the most part the house is vacant. but i keep the heat on for me to work in warmth. I was going with more of maybe a bad ground to the thermostat on the coil, and is why i was thinking of adding my own just not sure if this will cause any other problems or is a good idea at all. Im not an electrician but i dont see how it could hurt (also spoke to a friend that is in the hvac field and says he has not seen this happen before so... )
#5 |
Hvac Pro
Is there a brand name of the coil and what is it? I have seen some really poor quality A/C coils fail prematurely so quality can be an issue. I have never seen your problem in 30 yrs and would suspect some environmental problem.
| Display Modes | |
| Water Heater troubles | AZJD | Plumbing | 20 | 02-16-2012 11:10 PM |
| Hot water pipe making scary noises - Please help!!! | Sarah24 | Plumbing | 4 | 12-16-2008 11:24 AM |
| Filling a Cast Iron radiator system | insulatorpro | HVAC | 7 | 10-07-2008 12:31 AM |
| Is 1/2 Pex more restrictive than 1/2 copper? | twilightcall | Plumbing | 19 | 06-24-2008 08:32 AM |
| Help! Water Problem no one can solve! | Goonky | Plumbing | 4 | 12-24-2007 10:03 AM |
